3 members (panic, baldeagle, 68ironhead), 81 guests, and 4 robots.
Topics128,014
Posts1,055,330
Members48,419
#527749 04/13/2009 3:06 AM
Hello,
My clutch pedal is installed but isn't currently attached to anything.
Just wondering how it is attached to the trannie.
I found a hook with a threaded end that I beleive is used but am not sure where it hooks up to?
Any help would be great, thanks.
41chevy!! #527779 04/13/2009 3:50 AM
I
I Offline
The threaded end goes through the opening in the clutch fork. One nut on each side of the opening. The hook goes around the lower end of the clutch pedal, it should look like a hook too.
Can send a pic if you need one.
InMy40s #527784 04/13/2009 3:56 AM
If you have a picture, I would appreciate it.
It would help out alot.
Thanks!
41chevy!! #527787 04/13/2009 4:02 AM
Take a look at The 1941 Shop Manual (Thanks to Keith Hardy) and you will note that the bolt and nut attach to the clutch fork. There should also be a return spring attached to a bracket just forward of the flywheel housing. Procedures for repair and adjustment can be found in the shop manual also.
If you need a photo I'll send you one tomorrow.
My 1941 in the Stovebolt Gallery
My Photo Album
But I tried, didn't I? ... At least I did that. RP McMurphy
The past belongs to the future...but only the present can preserve it.
Besides the noble art of getting things done, there is a nobler art of leaving things undone.
