1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 161 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 161 | some of you may remember I burnt a hole in a piston. it was hard, but I got it running and I'm happy! what all I did: -replace piston -valve job -carb kit -plug wires =then it locked up. turned out starter was sticking to the flywheel -put in 4th gear and rocked it =then it turned over but no spark -measured all volts and ohms -replaced faulty coil =it runs! so i check vitals: radiator stays cold. to do: -replace lower radiator hose. it's blocked! =I decide to drive 2 inches: no brakes. check under truck. to do: -replace brake line =also to do: adjust valves but I'm happy with this!!! | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Great to see your making progress, Steady as she goes.  | | |
