I was wondering if any of you have had any luck with some sort of a windshield visor that actually fits the outline of the roof in the front. I took a chance and ordered one of the aftermarket ones and checked the fit only to find it doesn't very well, In the center it is about 1/2" away from the roof edge. You can force it up into place with some pressure but when the truck is painted and you are installing it, that doesn't seem too good and you certainly dont want to bend or kink it. It also seems pretty wide, about 7". Has anyone used some sort of visor on the second series 55-56 trucks and had it fit well? Are they all that wide? thanks...
