6 members (Gray_Ghost, tclederman, Gdads51, moparguy, Otto Skorzeny, 1 invisible), 80 guests, and 12 robots.
Topics128,078
Posts1,056,027
Members48,433
I have a 49 GMC and sort of think life would be easier if I could find a 1/2 decent cab. Mine is horribly rotted out and there is one guy on stovebolt that has a 51 Chevrolet cab. Would they be the same? Or would I go to put it all together and realize the firewall hits my 248 power plant? Or would the doors not bolt up on it, or what unforeseen problems is there, if any with replacing a GMC cab with a Chevy cab??
[email protected]
Whether you think you can or can't, you're right.
Also--in 2004, I invented the spotting alert network in stovebolt after seeing so many trucks when driving around. So that means I am cool.
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
They are the same, doors & all. The gauges maybe different in color & the way they look but will fit into the holes..Joe
As stated above, the cabs are the same. GMC made up for the extra length of the engine by using a different radiator and radiator mounting.
