7 members (Shade Baby, 68ironhead, rinemb, Otto Skorzeny, elhippie64, Gdads51, 1 invisible),
214
Mod | | | Forums66 Topics128,095 Posts1,056,075 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 52 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 52 | I have a 49 GMC and sort of think life would be easier if I could find a 1/2 decent cab. Mine is horribly rotted out and there is one guy on stovebolt that has a 51 Chevrolet cab. Would they be the same? Or would I go to put it all together and realize the firewall hits my 248 power plant? Or would the doors not bolt up on it, or what unforeseen problems is there, if any with replacing a GMC cab with a Chevy cab?? [email protected]
Whether you think you can or can't, you're right.
Also--in 2004, I invented the spotting alert network in stovebolt after seeing so many trucks when driving around. So that means I am cool.
| | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | They are the same, doors & all. The gauges maybe different in color & the way they look but will fit into the holes..Joe | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | As stated above, the cabs are the same. GMC made up for the extra length of the engine by using a different radiator and radiator mounting. | | |
