9 members (John Dlugos, Buckeye998, Gray_Ghost, Gdads51, dt235sd, rfs56trk, BCBill, Otto Skorzeny, Dusty53),
236
0
Mod | | | Forums66 Topics128,101 Posts1,056,172 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | I would like to find a gasket set for my '53,6100,two speed rear axle.Any sugestions? | | | | | Joined: Mar 2009 Posts: 93 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 93 | Yea I got two. Get some gasket material and make it or silicone. I know that's not what your looking for but I doubt if anyone makes it, at least I haven't seen it | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy PapaJ, Fel-Pro p/n RDS5050, 10 holes for the cover, p/n RDS11855, 10 hole for between the diff. and housing, that's if it has the rear end it left the factory with. If you could post some dimensions and number of holes I could possibly confirm, hope that helps. | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | That gasket has come before... let me do a search and get back. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | I think this was the post I was looking for:
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Board=5&Number=439777&Searchpage=1&Main=60670&Words=%26quot%3B5049%26quot%3B&topic=0&Search=true#Post439777 A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | What I really need is gaskets for the side diffs. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | We have been using RTV instead of gaskets for many years on our over the road trucks. Eaton and Meritor uses it from the factory. For a quick fix 30 to 50 years ago, we used to loosen the diff a little, wrap cotton string around the whole thing 4 or 5 times and retighten the diff. It would usually hold longer than gaskets. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy PapaJ if you're looking for the axle flange gaskets, measure the outside diameter of your axle, and the number of bolts retaining them, and post that info here and I can figure it out for you, or you could just use silicone. | | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | It could be splitter for the two speed that is leaking,Haven't had a chance to clean it off yet. | | |
