| | | Forums66 Topics128,034 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 52 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 52 | the coil in my 51 gmc looks identical to the coil on my Jacobsen Garden tractor. They are absolutely identicla. Delco-coils. And I know at advanced auto you can buy a coil that looks the same for about 10-18 bucks. My question is: Are coils specifically 6 or 12 volt? As long as it looks the same, is it right to use? My coil is bad, I have no spark and I want to get a coil but don't know if I can get one if i say I need a 6-volt. Or is there even a need to specify? I just don't know anything about electricity. Thanks. [email protected]
Whether you think you can or can't, you're right.
Also--in 2004, I invented the spotting alert network in stovebolt after seeing so many trucks when driving around. So that means I am cool.
| | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | Are coils specifically 6 or 12 volt?
Yes they are & some have the resistor built in...Joe | | |
