2 members (Gray_Ghost, 1 invisible),
179
Mod | | | Forums66 Topics128,109 Posts1,056,269 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 84 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 84 | I'm mounting an original hood ornament on my '53 3100 and I had a simple question. Should I just eyeball the mounting or are there some quidelines about where it should be mounted ie. "X" number of inches from the back of the hood?
1953 3100 | 1958 3/4-ton NAPCO
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The original 47-53 truck hood ornament, "986162 HOOD ORNAMENT - TRUCK", came with a template for locating the holes. Maybe someone has a template and will send it to you. Do you have an old, original ornament or a reproduction ornament?
| | | | | Joined: Aug 2008 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 52 | If its the bird like on the 54's I have the install instructions for that one. | | | | | Joined: Sep 2007 Posts: 84 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 84 | My hood ornament is an original but it is not the eagle. It's the other one. If anyone has a template out there that would be great. Thanks for the help.
