1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#526591 04/09/2009 5:48 PM
Hi guys,
I´m not ending to understand the caster and camber business. In few words, what do I have to change or adjust when the truck has excessive wear tires(from outside)?
thanks
alfonso #526595 04/09/2009 6:01 PM
alfonso,
The toe setting is probably the culprit. Excessive toe-in would tend to wear the outside of the front tires as they scrub down the road pigeon toe fashion.
Stuart
alfonso #526597 04/09/2009 6:07 PM
H Online: Content
Camber is the tilt of the tire in or out at the top, and that is what causes off-center wear. If you've got wear at the inside of the tread, that's negative camber,and it probably means there's wear at the king pins, or the wheel bearings are a little loose. Once you're sure all the wear points are corrected, then it might be necessary to bend the axle to correct the camber angle. That's a professional-type operation with special tools and HEAVY DUTY jacks!
Caster is corrected by using a tapered shim between the axle and the springs, or if one side is wrong, the axle can be twisted by using special lever arms and hydraulics. I grew up around a shop where we did straight axle alignments, and it's a tough job sometimes!
thanks Jerry and Stuart I knew that you can help me!!
Alfonso
