8 members (Rusty Rod, TUTS 59, Peggy M, 3B, J Lucas, David Bush, Southerntruck, 1 invisible),
103
Mod | | | Forums66 Topics128,065 Posts1,055,863 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 112 Shop Shark | | Shop Shark Joined: May 2007 Posts: 112 | Hi guys, I´m not ending to understand the caster and camber business. In few words, what do I have to change or adjust when the truck has excessive wear tires(from outside)? thanks | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | alfonso,
The toe setting is probably the culprit. Excessive toe-in would tend to wear the outside of the front tires as they scrub down the road pigeon toe fashion.
Stuart | | | | | Joined: Feb 2004 Posts: 29,776 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,776 | Camber is the tilt of the tire in or out at the top, and that is what causes off-center wear. If you've got wear at the inside of the tread, that's negative camber,and it probably means there's wear at the king pins, or the wheel bearings are a little loose. Once you're sure all the wear points are corrected, then it might be necessary to bend the axle to correct the camber angle. That's a professional-type operation with special tools and HEAVY DUTY jacks!
Caster is corrected by using a tapered shim between the axle and the springs, or if one side is wrong, the axle can be twisted by using special lever arms and hydraulics. I grew up around a shop where we did straight axle alignments, and it's a tough job sometimes! Jerry
| | | | | Joined: May 2007 Posts: 112 Shop Shark | | Shop Shark Joined: May 2007 Posts: 112 | thanks Jerry and Stuart I knew that you can help me!! Alfonso | | |
