1 members (GMCJammer51), 122 guests, and 5 robots.
Topics128,266
Posts1,058,386
Members48,485
#52665 11/20/2005 6:02 PM
I had picked up a shudder under acceleration in my 49 1/2ton with 216.
I made the cardinal sin of doing two things before testing it out so I'm not sure which was the culprit.
I did find that the vacuum line fitting going into the carb wasn't completely tight but I also replaced the plugs which were starting to carbon up.
Question. When replacing the plugs, I noticed that the plug in cylinder 5 appeared to be fouled. Could a vacuum leak cause one plug to misfire?
Anyway, she is running fine again so hopefully I fixed the problem. Thanks to all.
#52666 11/20/2005 6:44 PM
hrockwell,
It is great that you took the time to report back, I am sure everyone appreciates it.
I think the vacuum leak would affect the entire system. Number 5 was susceptible to this problem more than the other cylinders. Who knows why? As my cousin used to say, "It'll develop". smile
Stuart
