1 members (baldeagle), 108 guests, and 4 robots.
Topics128,014
Posts1,055,328
Members48,419
#525885 04/07/2009 11:35 PM
Whats the quick answer when I'm looking to make a Task Force better on the highway. I know the T-5 is the answer. Which one?
If you have a floor shift, the T5 may be the quick answer. If you have three on the tree, I would find and install the three speed overdrive.
Stovebolts are good for the heart
I beleive the actual question is "which T-5? ". I won't claim to be an expert on them, but it seems that the NWC version used in the S10 is the most recomneded.
Bill Burmeister
Riding in the Passing Lane
The S-10 T-5 87 on back is the best one to use. The 88 up used an elec. speedo & your cable will not hook up to it. There is a tag on one of the rear houseing bolts that ID it. In the left lower corner is the number you want. It starts with 1352. Take that number & bring up a chart on the internet & it will give you the ratio's. You want at least .076. .072 is better. .086 is not worth putting in unless you have a high rear end or very sluggish engine. 1352-145 is the most common. It comes on 85-86 S-10s & has good ratio's.
1972 Chevy c10 Cheyenne Super
My daily driver is a '86 S-10 and its about ready to retire. I think it just donated its transmission for a good cause. I hate to lose the column shifter though. Thanks for the information.
