1 members (Gray_Ghost),
77
Mod | | | Forums66 Topics128,128 Posts1,056,358 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 42 | Whats the quick answer when I'm looking to make a Task Force better on the highway. I know the T-5 is the answer. Which one? | | | | | Joined: Jan 2009 Posts: 106 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 106 | If you have a floor shift, the T5 may be the quick answer. If you have three on the tree, I would find and install the three speed overdrive.
Stovebolts are good for the heart
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I beleive the actual question is "which T-5? ". I won't claim to be an expert on them, but it seems that the NWC version used in the S10 is the most recomneded.
Bill Burmeister | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The S-10 T-5 87 on back is the best one to use. The 88 up used an elec. speedo & your cable will not hook up to it. There is a tag on one of the rear houseing bolts that ID it. In the left lower corner is the number you want. It starts with 1352. Take that number & bring up a chart on the internet & it will give you the ratio's. You want at least .076. .072 is better. .086 is not worth putting in unless you have a high rear end or very sluggish engine. 1352-145 is the most common. It comes on 85-86 S-10s & has good ratio's. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2006 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 42 | My daily driver is a '86 S-10 and its about ready to retire. I think it just donated its transmission for a good cause. I hate to lose the column shifter though. Thanks for the information. | | |
