| | | Forums66 Topics128,068 Posts1,055,883 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#52567 11/18/2005 1:27 AM | Joined: Sep 2005 Posts: 67 Member | | Member Joined: Sep 2005 Posts: 67 | I have one of those chrome type 'breather'caps on my valve cover on my st6 250 and it is beggining to seep a little oil and it's getting on the cleaned and painted motor ... on my "400" eng in my other 67 c-10 it has one of those hoses from the valve cover to the air breather ...some kind of emmissions control thing I guess...not having much effect I'd say... my question is will the PCV valve take care of venting if I close off the one from the covers to the air breather and change the chrome one on the 250 to a basic cap to stop the minor leaks?...
TIA | | |
#52568 11/18/2005 2:01 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Could it be that we just need a new gasket on the leaking cap? The p.v.c. system should function but there must be a source to allow air to enter the engine otherwise you will create a vacuum in the engine and your fuel pump might stop working | | |
#52569 11/18/2005 3:02 AM | Joined: Sep 2005 Posts: 67 Member | | Member Joined: Sep 2005 Posts: 67 | Not sure the gasket would stop it...it's in pretty good shape...I think the dripping is coming from the openings on the underside rather than the gasket | | |
#52570 11/18/2005 4:39 AM | Joined: Mar 2005 Posts: 75 Member | | Member Joined: Mar 2005 Posts: 75 | Its time to replace with a new one. it is dirty or you could clean it out with a degreaser. you must use one are like in the post from 3B. it will crete to much vaccum on the crank case and suck more oil out the PVC value.
super250six | | |
