| | | Forums66 Topics128,014 Posts1,055,333 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 150 | Has anyone hooked up a remote starter, one with the two clips and the starter trigger? If you have, please tell me how to do it...the instructions don't mention a '50 chevy truck. Thanks. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | starsfan,
Remote starter switches only work with solenoid type starters. Unless your '50 has a automatic transmission or has been modified it should have a 'stomp starter' which won't accept a remote starter switch.
If you do have a solenoid type starter, one alligator clip will attach to the large BATT lug on the solenoid and the other will attach to the small terminal on the solenoid with the little wires on it.
Stuart | | | | | Joined: May 2004 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 150 | Yeah, I kinda' figured. Thanks. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | A large screwdriver or prybar makes a remote starter for a stomp start truck. | | |
