| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 150 | Are condensor's the same whether you have original 6-volt system or if you've upgraded to 12-volt system? Also, are points the same, whether 6-volt or 12-volt? Thanks. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | You would have to check by part number but my guess is that they would work fine on 12 V. The only possible change that I can think of is maybe the condenser is a different value to go along with the different impedance of the 12 V coil. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | You might want to post your year and make of truck (and/or put your truck year/make/model in your Profile), just in case there are subtle differences that people might want to bring to your attention.
It looks like the same condenser was used from 47-62 (maybe '34-'72?) and a different 6-cylinder condenser was used from '63-'76. Since 12v became standard on Chevrolet trucks in 1955-2nd series, it looks like the 6v condenser should work (maybe someone will know if pre-47 6v condensers will work with a 12v conversion).
Nonetheless, the same part numbers for condensers and points are shown for at least 1946-1962 216/235/261 engines.
Maybe the 6v condenser works because a ballast resister is used before the coil/points in 12v GM vehicles (up through 1976?)?
Points are the same (for 6v or 12v systems) - whatever fits your distributor.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The points & cond. are the same for 6 & 12 volts but tou must use a resister in the circuit for 12 volts. You should have a bypass system for the resister when starting. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
