Brrrr
place holder
8 members (Peggy M, klhansen, Charles in CA, Hush, Nick in Manitou, 41 chev, Bucker, 1 invisible), 179 guests, and 4 robots.
Topics128,270
Posts1,058,408
Members48,485
I ordered a fuel flex line that connects the petcock to the steel gas line and it's a different size than the orignal. The new one is tagged with the correct part number and year for the truck. It looks like the one I took off is 5/16th inch and the new one is smaller, probably 1/4 inch. If I start adding fittings to adapt the new one it may kink a little because of the added length.
Should I just use barb fittings with gas hose held on with hose clamps?
I know, it's not a major issure but I was wondering what y'all thought.
Union, Justice and Confidence
My friend the helicopter pilot says also the pitch of
the threads on the fittings is wrong also.
He's going to make me a new line with fittings.
could not use mine either.
Cavebull
cavebull
Stovebolts - so easy even a Cavebull can do it.
https://www.flickr.com/photos/dodsonbrett/collections
I bought a new petcock with pipe threads on both sides and had a local hydraulics shop make two short hoses with matching pipe thread. I made my own rigid line from a length of 5/16 brake line. You should find that both the tank and pump have a pipe thread and you can get to any type of thread from there.
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
Thanks guys, I'm a little out of practice with working on the old truck. I guess I need to warm up a little first like a 216 does so I don't let these little bumps in the road slow me down.
