3 members (RLB, qside, Gray_Ghost), 71 guests, and 1 robot.
Topics128,072
Posts1,055,907
Members48,429
#524831 04/05/2009 5:52 AM
How do I remove the pilot bearing from a 235 crankshaft? The Shop Manual tells me to use tool HIJKLMNOP which doesn't help me. Do I need to buy a small version of a standard bearing puller? If so, then I assume there is a shoulder on the back side of the bearing that I can grab and pull?
To replace the bearing, do I just pound a new one in using a socket wrench socket of the same diameter?
I heard once that if you fill it with grease, then get a bolt that is just small enough to fit in the hole without scraping the sides, and push the bolt in. maybe tapping with a hammer or something. The grease will then get displaced and push the bearing outwards. don't know if it works or not. worth a try.
[yrl=http://viewmorepics.myspace.com/index.cfm?fuseaction=user.viewPicture&friendID=43825635&albumId=1717519]More pictures in MySpace[/url]
davidn #524909 04/05/2009 3:01 PM
yeah, the grease trick usually works, use a piece of wood dowel to pound on the grease - the new one shouldn't take much pounding in, more like "tap" wink
heard the same tip as well. i was told that if you get the grease to dispense under enough pressure it will pop the bearing with out the ram rod, but i have heard of useing a tap rod as well. would assume wood is better than a hard steel as you are less likely to scratch anything.
ed
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
I use the grease and wood dowel trick.Fill the hole up with grease then insert same size of dowel as hole and tap it with a hammer.Repeat this a couple of times and it will be out.
1951 3100 Chevrolet
I have heard that you can also use wet toliet paper instead of the grease. Suppose to be less messy and easier to clean up when you are done.
Hope this helps.
Kent S Butler
'56 Chevy 3100
Houston, TX
1 Offline
Just did this the other day and used Play dough and dowel. worked like a charm and easy to clean up. Slickest thing I ever saw, found that hint on this board.
I wasted 2 days on using a pilot bearing pulling that didnt fit the hole.
1951 Chevy 3100 5 window with a 1958-60 235 and original 4 speed.
Cool! I tried the Play-Dough trick and it worked like a charm. The pilot bearing was out in less than 10 minutes!
Then I screwed-up and installed the new bearing without any grease. I had to beat the daylights out of it to push it in place. I hope I didn't damage the bushing. Doh!
dang
