4 members (Shaffer's1950, HandyAndy, jay d, 1 invisible), 66 guests, and 0 robots.
Topics128,205
Posts1,057,429
Members48,471
I have not yet entered into body repair /painting but here is my background. I am a woodworker, I spray different types of lacquer with HVLP.
So here is my question-My wife's '99 Honda Accord has a few rust spot on the lower panels. I was thinking about using this as a test area. So after I remove the paint/rust I will prime and then use a base coat and clear coat. My question is on the adjoining areas will I have a problem with the new base coat going over the old clear coat, then new clear coat over everything?
Sorry if I am not making this clear.
Thomas,, as long as you prep all areas you shouldnt have a problem. Everything needs to be sanded.
What I do is sand all primed areas and areas where I want to put color on, with 400 grit sand paper. either by hand or with a D.A. sander If im blending color within the panel or onto an ajacent panel I sand the rest of the Panel and the entire ajacent panel with 800 on a 3m velcro foam pad on a D.A sander , And then use a gray scuff pad on the areas where I cant get the sand paper to.
Or if you dont want to use the 800, you can use 1000 grit wet by hand and then use the gray scuff pad. Once that's done and cleaned properly you should be good to go.
Once all your areas are colored and blended, spray 2 coats of clear over everything.
Good luck, hope this helps.
