6 members (Cletus1950, Wayne67vert, Peggy M, Hotrod Lincoln, Otto Skorzeny, 59 fleet), 157 guests, and 11 robots.
Topics128,106
Posts1,056,217
Members48,436
Pizza man here for some advice. I have a 1942 1 1/2 ton and am thinking of a conversion of my drivetrain or???
1. replace motor with 8 cylinder, auto trans, rearend and what do I do about brakes??
2. Buy cab and chassis of flat bed tow truck and put my cab on chassis.
Questions would be on #1 how much work and can it be done and how much$$ versus #2 buy cab and chassis and install my cab $$$
Thanks in advance for any help!!! Jack oldworldpizzatruck.com
Try this tech tip, might give you some ideas.
http://www.stovebolt.com/techtips/bigbolts/p30swap/
If money is a big concern then mostly stock, or with a newer 235 or 261 might make the most sense. Also think about a dual circuit brake system.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Motor runs beautiful, problem is I need to go on the highway and do at least 50/55.
And be able to stop!!
Then a rear axle swap to gain faster gears. And the dual circuit brake system with a booster for the brakes would be the minimum to go faster and add some safety.
What does the truck weigh, and how big is the body?
Do you have enough power to go as fast as you want?
Grigg
---All pictures---
He has a wood-fired brick oven on the back of his Pizza Truck. Probably the hottest custom job here.(900 degrees) big_eek
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
Truck weighs 12k lbs
At 12,000 lb I think you better stick with the gearing you have unless you upgrade for more power and lots more brakes.
If you want to safely go faster with a 12,000 lb truck you've got a lot of work to do.
Grigg
---All pictures---
Who drives the truck? If this is a business tool does it get driven by employees?
If so, their are two additional considerations. First your possible liability issues are increased, so safety is an even bigger concern. Second you can't count on the driver knowing the truck and knowing when to slow down, so good brakes and ease of operation are crucial to safety.
I am the only driver. What are dual circuit brakes???
