7 members (cmayna, dt235sd, baldeagle, 1955 1 Series, NJC, 2 invisible), 93 guests, and 6 robots.
Topics128,016
Posts1,055,337
Members48,419
#5232 09/11/2002 3:55 AM
I'm back to work on my truck now after a few weeks away from it. I have it mostly back together and fired it up after a few months of not running. My starter is not disengaging though. Its a 61 235 in my 52 baby, it has always ran good. Any ideas on how to correct this without replacing it? I haven't pulled it out yet to take a look but thought I would get some good advice from all the expericend people here first. It does disengage if I let off the starte pedal before it starts but when it starts it grinds to beat the band. Any help would be great. As always thanks in advance.
If it ain't broke I ain't worked on it.
#5233 09/11/2002 11:58 AM
Just so we can understand this, are you saying that you have the old foot actuated started on a newer 235 ?
1951 1 Ton Completed
#5234 09/11/2002 1:19 PM
i've had this happen before. sometimes stuff sits and binds up---darned old rust gets everywhere. usually a little cleaning and brushing and a good coat of lubriplate fixes the problem. i like that stuff, and use it a bunch--even to break in a new cam. there can be mechanical problems---like the return spring broken or the spring has lost it's springy (that's a technical term to a hillbilly) but usually return springs are pretty tough. yank it out, clean it up, and go again. then go outside and fix the starter. ooops---sorry peg. (another scolding e-mail for koolkar from the little general. wink cool
#5235 09/11/2002 5:42 PM
Gotcha koolcar. I'll give that a try, then I'll try your suggestion on the starter also.
#5236 09/11/2002 6:48 PM
remember the lubriplate. cool
#5237 09/11/2002 8:05 PM
Look at the bendix,,,GEAR for cracks,,,,,IN THE GEAR!!! and check the ring,,,,,GEAR for false teeth,,,, I mean worn teeth!!!
Make sure all starter bolts are tight and there are no cracks in the housing(nose-cone of the starter).
#5238 09/11/2002 10:21 PM
I'll look at her teeth and check her for cracks like you suggest. Going to get me kicked out of the forum. Appreciate the suggestions, where can I get lubriplate? Will KY work if I can't find it? Thanks for all the help, I hope to get her running tonight.
#5239 09/12/2002 4:26 AM
I checked the starter out it looks everything looks good except one thing. The linkage from the foot starter is hitting the firewall and not letting the the starter gear disengage from the flywheel. The spring is good and strong, it looks new. If I take the linkage off it lacks about a quarter inch of movement to disengage. Not sure what to do, maybe cut a little out of the linkage and weld it back. What do you think? Every seen this before?
#5240 09/12/2002 4:44 AM
How are the cab body mounts?
It sounds like the cab may have shifted forward.I wouldn`t think that someone could have changed any of the linkage but it may be possible eek
#5241 09/12/2002 2:58 PM
I guess it could be the cab mounts, I didn't think of that. I didn't have the cab off but I did have the front clip off, the cab mounts I'm sure aren't in that great of shape and it could have shifted with all the time it spend on jack stands and the floor jack, it went up and down a few times in the last month thats for sure. Good idea, I'll check that out tonight if the wife will let me. She asked me last night if she smeared some grease on her face if I'd notice her, who am I to disappoint her, I said sure I would.
#5242 09/12/2002 4:47 PM
Just don't get your lubricants mixed up. No KY on the truck. Lubriplate is white lithium that has a special adhesion additive. You can also use the white lithium in a spray can. There's another grease that is better for open gears, it is black and comes in a caulk tube. Far better for sticking to gears and stuff, but next to impossible to clean out of your clothes and skin.
Fred
52 3600
69 C-10
#5243 09/12/2002 5:51 PM
This is a problem on my project truck because the cab is collapsed. There should be a specified clearance between the toeboard and the frame, I think it is probably close to an inch, but it is in the shop manual. What you will find is that if you change the length of the linkage, you will then have a problem with the switch.
#5244 09/16/2002 3:30 AM
Mechainiac
How the heck you new the cab mounts were the problem I'llnever know. How many of these old trucks have you worked on? That was it, I shimed it up and it works great. I guess when I'm done with this one the next one will be much eaiser.
#5245 09/16/2002 8:12 AM
I have informants looking at your truck while you are sleeping grin
Really just a view of experience and a process of elimination cool
