2 members (Otto Skorzeny, Charles in CA), 79 guests, and 0 robots.
Topics128,051
Posts1,055,764
#523728 04/02/2009 4:23 AM
I finally gave up on rebuilding a 216 and decided to install a 235. I did a search on disguising a 235 to resemble a 216 but found no help. Anyone got trick valve covers to fool the eye?
Dan B. #523731 04/02/2009 4:29 AM
OLTrucks
Unregistered
OLTrucks
Unregistered
Use the valve cover from your 216 and the two long rocker arm bolts that hold on your valve cover to the 216 a 235 gasket cut off the tabs that stick out for the four bolts and thats done. then use the water pump adapter plate your good 216 water pump and your crank pully and you about a good as one can get.
Mike
#523739 04/02/2009 4:39 AM
Thanks OLTrucks. That sounds way too easy.
Dan B. #523873 04/02/2009 4:03 PM
I've disguised mine. The 216 parts I have put on my 235 are: bellhousing, flywheel, starter, distributor, fuel pump, road draft tube, and of course the valve cover and water pump (with adapter plate)
Of course the short side cover is the most obvious giveaway, but most people won't know the difference.
Steve
'49 3800
'52 3600
'57 3100
If you have a oem oil filter setup, you can take it off in order to further the disguise.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
If you really want a 235 to look like a 216, with the tall pushrod cover, you need a 1941-49 235 "Hi-Torque" engine. Is this one being discussed on the Inliners' BB still available? These blocks came with the low pressure oiling system, but it was once fairly common to convert them to high pressure with precision insert bearings.
Hoyt
hoyt #524219 04/03/2009 12:49 PM
Or make a tall sidecover. More nostalgic disguises are in the works.
http://good-times.webshots.com/photo/2188306040023244788IfZWDB
You Tube
Curt B. #524469 04/04/2009 2:44 AM
Curt B.,
That is a terrific side cover (and truck - I hope that mine comes out even close to it!). Did you make the sidecover yourself? As I recall, our member 6cylindersovertexas has a somewhat similar side cover on his 261 in a 1937 pickup. Of course, a dedicated nit-picker would complain about the upper row of attachment screws being in the wrong location, but I won't tell anyone. One could also "install" some fake 1/4-20 pan head screws up where the original 216 side cover attaches to the head, and cover the 'real" screws that attach the new sidecover to the upper face of the side of the 235 or 261 block with a "decorative" strip of machined aluminum to complement the rest of the sidecover. That would probably be easier that converting a 41-49 Hi-Torque 235 to full pressure and insert bearings.
Hoyt
Hoyt
