| | | Forums66 Topics128,048 Posts1,055,663 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#52358 11/14/2005 1:30 AM | Joined: Nov 2003 Posts: 113 Member | | Member Joined: Nov 2003 Posts: 113 | I have a 54 3100 235 Hydramatic. When I take-off from a stand-still it quickly shifts up to third gear. As I try and accelerate I get what sounds like an octane ping and at the same time valve chatter/rattle. Had the head done about 1,000 miles ago with hardened seats and valves. Rockers are original as are pushrods and solid lifters. What's up and how do I solve the problem(s)? Thanks! :confused:
Bruce (I love My Truck) Miller
1954 5 Window 3100 Chevy Pickup - Driver 1929 **** Model A Pickup - Restoration
#52359 11/14/2005 3:31 AM | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | My guess would be that if it shifts too fast then the throttle pressure link is too long and needs to be adjusted shorter. Engine timing could be too far advanced making it ping under load. | | |
#52360 11/14/2005 5:37 AM | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | check the timmimg. http:/community.webshots.com/user/danps482
dan-pa
#52361 11/14/2005 6:56 AM | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Pick yourself up a repair manual or go to the local library and check out an old motors manual. They will have instructions for adjusting the transmission shift points. As Greq_H points out it has to do with the length of the throttle pressure linkage. | | |
