3 members (hardshell, klhansen, ShopRag), 44 guests, and 3 robots.
Topics128,030
Posts1,055,428
Members48,422
#521886 03/28/2009 1:51 PM
Can anyone tell me what they used for a 12 volt wiper motor
on a 46 chevy truck..I tried the single blade universal motor type but I can't seem to get it tight enough on the bushing that goes through the body..there seems to be no place behind motor to
bace it..thanks in advance
1946 chevy 1/2 ton panel
1937 ford coupe
jdhoward #523459 04/01/2009 5:37 PM
OLTrucks
Unregistered
OLTrucks
Unregistered
There should be a spacer between the inside of the cab sheet metal and the motor to help maintain pitch and shaft length on the outside of the cab. Any supplier should be able to supply one for you or have information on what you would need.
Mike
