2 members (carbking, TUTS 59),
108
Mod | | | Forums66 Topics128,029 Posts1,055,416 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 112 | Can anyone tell me what they used for a 12 volt wiper motor on a 46 chevy truck..I tried the single blade universal motor type but I can't seem to get it tight enough on the bushing that goes through the body..there seems to be no place behind motor to bace it..thanks in advance
1946 chevy 1/2 ton panel 1937 ford coupe | | | | | | OLTrucks Unregistered | | OLTrucks Unregistered | There should be a spacer between the inside of the cab sheet metal and the motor to help maintain pitch and shaft length on the outside of the cab. Any supplier should be able to supply one for you or have information on what you would need. Mike
