7 members (Hotrod Lincoln, bobfake, GRNHydra, tclederman, Woodcmiami, Otto Skorzeny, 2-Ton),
43
Mod | | | Forums66 Topics128,091 Posts1,056,034 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 39 Apprentice | | Apprentice Joined: Jul 2007 Posts: 39 | I have been reading through numerous posts here and it appears that the old steering column/wheel combination on the ~40-60s truck are dangerous in front end collisions. To what year does this extend? and what are the alternatives? Are aftermarket columns safe like Flaming River etc? Thanks all for the input! | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | '60 was the first year for the separate column/steering box, previous years used the 1 peice column/box.
Bill Burmeister | | | | | Joined: Jul 2007 Posts: 39 Apprentice | | Apprentice Joined: Jul 2007 Posts: 39 | Thanks guys for the tips! Now it makes more sense what the issue was before. I have always wanted a steering column with an airbag but I have never found anyone to make them for retrofit into older trucks. Cavebull: I'd be real interested in what you are planning on doing. Right now my steering is stock so everything lines up straight and just has a rag joint. I have been thinking about moving the steering wheel more into the dash because it's just too in my face at the moment  | | | | | Joined: Jan 2008 Posts: 239 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 239 | Starting in 67 the federal gov't mandated collapsable columns in cars, and trucks too I think. The goal was to make it so it didn't go through you in the case of a head-on collision. Might want to check later model trucks for this.
Devin
If you can't hose it out it ain't a truck
55 3100 63 Corvair Monza 64 El Camino 72 240Z 01 Suburban
| | | | | Joined: Jul 2007 Posts: 39 Apprentice | | Apprentice Joined: Jul 2007 Posts: 39 | Thanks Devin, do these bolt in a 64? or is the angle of the floorboard different etc? | | | | | Joined: Jan 2008 Posts: 239 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 239 | I would imagine the column design changed with the trucks in 67, I know there were changes in the cars then. Some fabrication may be necessary, but that seems to always be the case.
Devin
