| | | Forums66 Topics128,211 Posts1,057,468 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 111 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 111 | Hey guys, need some help/advice. Got a gear oil leak coming from the rear of my 1957 chevy 3200 (3speed manual on the tree). its coming from where the drive train meets the rear of the tranny. Gear oil shooting up onto the undercarriage and bottom of bed. Is there a seal in the back of the tranny that I can replace? Can I do it without removing the tranny? Where do I get a seal?? THX - J.R. in VA | | | | | Joined: Jul 2008 Posts: 111 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 111 | also...how do I get the old seal out? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | J.R
Sorry about my first post - another example of my addled mind.
Wrenchbender Ret., thanks for the quick and kind correction.
Tim
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I think TC thought you ment rear engine seal. To replace the trans. rear seal you pull the drive shaft out & remove the seal. If the seal has a flange on it you put a chisel in back of it & tap it out. If not take a small chisel & hammer & dig into it. If you have a large socket about the size of the seal you can use it to hammer in the new seal. If not tap it carefully on the edge work ing around till it is flush with the houseing. A new seal is available from any parts store. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
