4 members (GMCJammer51, HandyAndy, IHPWR, 1 invisible), 65 guests, and 0 robots.
Topics128,214
Posts1,057,484
Members48,473
Hey guys,
need some help/advice.
Got a gear oil leak coming from the rear of my 1957 chevy 3200 (3speed manual on the tree). its coming from where the drive train meets the rear of the tranny. Gear oil shooting up onto the undercarriage and bottom of bed.
Is there a seal in the back of the tranny that I can replace? Can I do it without removing the tranny? Where do I get a seal??
THX - J.R. in VA
also...how do I get the old seal out?
J.R
Sorry about my first post - another example of my addled mind.
Wrenchbender Ret., thanks for the quick and kind correction.
Tim
Riding in the Passing Lane
I think TC thought you ment rear engine seal. To replace the trans. rear seal you pull the drive shaft out & remove the seal. If the seal has a flange on it you put a chisel in back of it & tap it out. If not take a small chisel & hammer & dig into it. If you have a large socket about the size of the seal you can use it to hammer in the new seal. If not tap it carefully on the edge work ing around till it is flush with the houseing. A new seal is available from any parts store.
1972 Chevy c10 Cheyenne Super
