0 members (),
102
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 8 New Guy | | New Guy Joined: Mar 2009 Posts: 8 | Is it anything to watch out for when you sandblast a rolling chassis with the A-arms and other items? | | | | | Joined: Oct 2006 Posts: 289 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 289 | don't blast around axle housings, gears, engines, bearings, bushing or other similar parts that sand would grind the c@@p out of. | | | | | Joined: Mar 2009 Posts: 8 New Guy | | New Guy Joined: Mar 2009 Posts: 8 | I think I will stick to sandblasting body only , talked to my brother & he says that using easyoff oven cleaner will strip anything you need to ,then pressure wash it. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | I bought some cheap scrapers at HF and was able to clean just about everything off my frame. Follow that up with some wire brushing and a good power wash and you should be good to go... unless you want perfection. Then you should take it completely apart and blast it. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | None of my jalopies are show vehicles. It is surprising what Simple Green and a good pressure washer will do. If I have a particular rusty spot on a frame or axle housing, I prefer a needle scaler. They knock rust off in a hurry and don't make a mess.
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | appletree, On my project I took it to a local Big Rig garage that cleans tractors/trailors on the weekends and they "Steam Gennied" it for me, it came out squeeky clean!..I highly recommend the steam cleaning followed by a good greasing of all fitttings when ya get it back. Tim | | | | | Joined: Nov 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 145 | I had my rolling frame blasted. I even had them take off the wheels to get the drums. Sand did get inside the hubs. But it wasn't hard to clean. It needed cleaned and re greased anyways. In the Gallery[yrl=http://viewmorepics.myspace.com/index.cfm?fuseaction=user.viewPicture&friendID=43825635&albumId=1717519]More pictures in MySpace[/url]
