| | | Forums66 Topics128,035 Posts1,055,564 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 159 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 159 | Hi I am restoring a 56 long bed, cant figure out from the diagrams exactly what cross member bar metal piece goes in what order from cab to rear. can someone tell me what height bar goes where?
56 stepside 3/4 ton longbed
| | | | | Joined: Jan 2008 Posts: 176 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 176 | Hi 56 stepside,
Don't know if it will help you but I can give you the order for a 1955 3200. There are 5 bars on my truck. Starting at the cab and working backwards the first two are the taller ones. Next (where the frame curves upward a bit) are two shorter ones followed by the last tall one. In between cross member number one and two and aft of number 5 there is a row of bolts that go through the wood without a cross member on the underside. | | |
