5 members (37 GC, ShopRag, klhansen, Hotrod Lincoln, 1 invisible), 178 guests, and 2 robots.
Topics128,147
Posts1,056,797
Members48,454
#522043 03/28/2009 11:03 PM
How do I disconnect the oil feed line? There's so much dirt that I can't see how it goes through the cylinder head. Do I just need to disconnect it at the fitting under the push rod cover?
195? Chevy 3800 dump truck
1973 Chevy C30 cab and chassis
1987 Suburban 3/4 ton 6.2L Diesel
The oil feed line is hand-pressed into a hole in the head. It should lift out of the hole fairly easily after you remove the shafts' bolts.
Thanks. That's kind of what it looked like but I wanted to be sure.
