1 members (MickeyP),
122
Mod | | | Forums66 Topics128,088 Posts1,056,114 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#52202 11/10/2005 4:04 PM | Joined: Oct 2005 Posts: 29 'Bolter | | 'Bolter Joined: Oct 2005 Posts: 29 | I have a GMC 2T flatbed w/ 2sp rear end that shifts off of manifold vacuum on a dash switch. It occasionally slips out of gear under load, causing engine to race. Lines appear to be intact, and I am wondering if I should pressure test the lines or simply convert it to a solenoid shift, if this is possible. Any thoughts? | | |
#52203 11/10/2005 6:57 PM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Sounds like a leaking line or diaphragm. I'd like to convert my 350 2-speed rear over to electric, so if anyone can help, I'm also interested. | | |
