7 members (68ironhead, moparguy, fonz8261, Otto Skorzeny, physcult, Bill Hanlon, Phak1), 76 guests, and 2 robots.
Topics128,128
Posts1,056,682
Members48,452
Cab is mounted on chassis on rubber mounts , firewall has been replaced, steering column and brake assembly fabricated and mounted, steering shaft geometry solved , power brake hydraulic assembly mounted. Currently working on fabricating a bell crank for the firewall to connect the antilock power brake system . I spent days getting the geometry of the steering wheel and brake pedal assembly fabricated so it will be a comfortable ride. Without the usual engine hump in this truck there is alot of room in the cab for making this a comforable ride. The engine is mounted just behind the cab between the rails.
Moderated
Moderated
/I see you were trying to use your ABS. Were you able to get it to work? I am doing a 59 Chevy on an 04 yukon frame. I would like to try to use the ABS and the air ride suspension.
twotone64
You just responded to a post from 2009 and the original poster hasn't been here since 2014...I don't think you'll be getting an answer to your question.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
twotone 64 Don't feel too dumb about replying to an old thread that is long outdated,it happens. Bolters look from all angles and sometimes get chapping on their cheeks from commentors just trying to help. You'll learn when to duck !!
