8 members (dt235sd, Lonnie, Wickedbass, Gabes-trucks, Ponchogl, Otto Skorzeny, 2 invisible), 193 guests, and 2 robots.
Topics128,081
Posts1,056,076
Members48,434
#520682 03/25/2009 4:51 AM
My 53 3100 was available in the new burgundy maroon color. The paint chart shows the pinstripe color should be gold-bronze for this combo. Anyone have close-up pictures of correctly pinstriped cabs and wheels? My existing cab has more rust than paint but I can see there was an original pinstripe.
Jim Carter sells an instruction sheet for striping.
The original data sheet shows Your truck color as Cape
Maroon, and is baking Dulux and the striping color as Gold which
is Duco.....Bill B.
More info.
1. Outer grill bars....Body color....Inner bars...thistle gray
2. Bumpers....Anvil gray
Bill B.
1952 Chevy 3104 Shortbed 5-window
Remember; Politicians and diapers both need to be changed
often, and for the same reason.....
Sorry, I have more info. concerning the wheels pin-striping. The 3100 has 3 pinstripes,
while the only other wheel that is striped
is the 3600,3700,3800, and 3900...they use
a 17 inch wheel and only 2 stripes...
The RPO wheel (15 inch) has no pinstripes...
The 3600,3700 reg. has no pinstripes...
The wheel pinstripes are the color same as the body stripe..
Bill B.
Checkout the width of the cab/body pinstripe. They supposedly ranged from 3/16" to 1/8" - these 1950stripes are at least 3/16" (on my 1954 Suburban they were 1/8").
The cabs I've seen are faded and worn. Is the beltline two stripes or one?
Thanks for the interest.
One
I am ready to start painting, I would like to get more information on the burgundy maroon paint/color/numbers. The auto parts stores could not get an exact match on the numbers provided for this color, what number did you end up using to end up with a burgundy maroon? Thanks Keith
Keith,
What numbers do you have?
What paint brand did not have a match?
Tim
Got these numbers from the Tech Tips/Painting/47-55 AD Paint Codes,
PPG 50350
DUP 93-72004M
RPO 2340
Both NAPA and Carquest paint people could not duplicate these numbers.
I am also considaring Permenent Red, which appears to be a deeper red then Swift Red.
Any help on these colors is greatly appreaciated.
Keith
k10 Offline
50350 appears to be Burgundy Maroon. You didn't provide the year of your truck however.
Cruise over here and scope it out for yourself.
http://www.tcpglobal.com/aclchip.aspx?image=1951-ChevroletTruck-pg03.jpg
It's the Auto color library.
http://www.autocolorlibrary.com/
Did you check with PPG? There are instructions at the bottom of the Tech-Tip.
K10 - Burgundy Maroon was a 1953 Chevrolet truck exterior color (it's in the 47-55 Colors Tech-Tip).
Tim
Sorry, its a 53 GMC. The auto library site was helpful, thanks.
All I need for now.
