0 members (), 162 guests, and 4 robots.
Topics128,089
Posts1,056,139
Members48,435
#521222 03/26/2009 5:47 PM
I want a radio for my '53 6100(12 volt)how new can I go to get one to fit without cutting the dash to make it fit with a speaker
in the original spot??
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
LMC and other vendors sell modern radios that will fit the opening. For more money you can buy a modern radio that has the same appearance as the original. They use the original style front including the bezel dial and buttons. I think they retail for just over $500.
1951 1 Ton Completed
You almost have to go with one designed to fit the original hole. Its almost impossible to find new radios that will fit without cutting
Can I get one from(for instance)a 1963 chevy or a '74??
1953 Chevy Two-Ton
I doubt that there are other years that fit properly. If you can find one that you can use one control hole and the cutout then you could make a faceplate to cover underneath. As far as year goes, what you need is a source of 12 volts in your truck. You also want to be able to use a conventional antenna.
Thanks for all the advice I'll see what I can do with it.
1953 Chevy Two-Ton
Moderated by  truckernix
