2 members (BC59, 1 invisible),
152
Mod | | | Forums66 Topics128,088 Posts1,056,110 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | I want a radio for my '53 6100(12 volt)how new can I go to get one to fit without cutting the dash to make it fit with a speaker in the original spot?? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | LMC and other vendors sell modern radios that will fit the opening. For more money you can buy a modern radio that has the same appearance as the original. They use the original style front including the bezel dial and buttons. I think they retail for just over $500. | | | | | Joined: Feb 2006 Posts: 37 New Guy | | New Guy Joined: Feb 2006 Posts: 37 | You almost have to go with one designed to fit the original hole. Its almost impossible to find new radios that will fit without cutting | | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | Can I get one from(for instance)a 1963 chevy or a '74?? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I doubt that there are other years that fit properly. If you can find one that you can use one control hole and the cutout then you could make a faceplate to cover underneath. As far as year goes, what you need is a source of 12 volts in your truck. You also want to be able to use a conventional antenna. | | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | Thanks for all the advice I'll see what I can do with it. | | |
