| | | Forums66 Topics128,154 Posts1,057,015 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#52156 11/09/2005 9:33 PM | Joined: Jun 2005 Posts: 50 Member | | Member Joined: Jun 2005 Posts: 50 | Befor I replace the bed it's easyer to stop the leak on the rearend and also the driveshaft to rear seals. It's a ten bolt rear and I don't know where to get the gaskets for this 3/4 ton 3600. Also how do I go about re gasketing it?
PJP
#52157 11/09/2005 10:49 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If it,s leaking at the pinion seal where the drive shaft yoke goes into the rear end you pull the drive shaft loose. Than remove the yoke. Than remove the 5 bolts that hold the flange with the seal. Replace the seal & reassemble the parts. The gasket & seal can be purchased at a parts store or American Classic parts. If the rear cover is leaking you can remove it & replace the gasket. If grease is leaking out the rear drums you will have to pull them & replace the seals. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#52158 11/09/2005 11:02 PM | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | I made gasgets out of a thin cardboard... used the old ones as a template....and they're working real fine! | | |
#52159 11/10/2005 1:26 PM | Joined: Jun 2005 Posts: 50 Member | | Member Joined: Jun 2005 Posts: 50 |
PJP
