1 members (baldeagle),
105
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#52148 11/09/2005 7:53 PM | Joined: Oct 2003 Posts: 297 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 297 | I have been reading posts on here for over a year trying to decide what I want to do with my 54 1/2 ton which will be used as a "semi" daily driver and some highway use. If I plan to keep the torque tube set up and stock 3 on the tree, it appears that my best set up would be (1) duel carbs (2) duel exhausts which I already have via split manifold (3)electronic ignition and (4) patricks ring and pinion. I am already running 15 inch tires. These appear to be the "bolt on" type things that an amateur can do that will enhance performance and pick up a little speed on the highway. I was lucky and my suspension and steering were tight when I bought the truck so I really don't want to fool with any of that right now. Maybe front disks later on. Am I too far off on my thinking?
54 3100 w/62 235 "Yosemite Sam" Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
#52149 11/09/2005 7:55 PM | Joined: Oct 2003 Posts: 297 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 297 | I forgot to add that I have already converted to 12 volt and electric wipers and plan on adding turn signals in the near future.
#52150 11/09/2005 7:56 PM | Joined: Oct 2003 Posts: 297 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 297 | I forgot to add that I have already converted to 12 volt and electric wipers and plan on adding turn signals in the near future.
#52151 11/09/2005 9:07 PM | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Djed50,
Like you, I've been reading alot of the opinions on what makes up a good daily driver, and trying to determine what direction I want to go.
I believe I'll probably end up going the T-5 route at some point. At least on one of the trucks.
I just can't go any great distance with them stock, like they are, and I'd like to be able to hit some shows etc. a little further from the house.
It sound as though (from your post) you're leaning towards keeping the torque tube. If that's the case, your plan is probably about the only way to go about what you want to end up with. It sounds logical and well thought out to me.
The addition of turn signals you mentioned is a very wise choice.
I would probably consider the brake upgrade in the very near future, as it's going to take more to slow down from your new found speed.
I would also add seatbelts or ? to your list, if you haven't already done so.
But that's just my opinion. | | |
#52152 11/09/2005 9:32 PM | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | djed50 I have red your post and thought I would throw in my 2 cents. I have a 53 5 window with a 235, dual Holley/Webbers, Fenton hedders and Petronix ing. I am running Patricks 3.55 in a torque tube with good results. Fuel mileage is about 15 mph. I think you are on the right track if you want a daily driver. It has served me quite well. Then I found a overdrive transmission and now I am in the process of changing everything over to an open drive line. A friend gave me a 55-1 rear end that I plan to use. The only reasion that I am going with an open drive line is that it gives me more options, and I plan to do some long trips with my truck. I have also installed the disc brakes on the front axle. I did not use a kit, figgered that I saved a couple of hundred bucks by making up my own kit. Hope this helps with your decision. Tom | | |
#52153 11/09/2005 10:40 PM | Joined: Oct 2003 Posts: 297 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 297 | JED - djed 50 stands for dumb jock ed 50. old football coach and player and i was 50 when i made it up - now 56. there are so many ways to go with these truks i have had a hard time deciding what to do and i appreciate everyones imput.
#52154 11/09/2005 10:55 PM | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Ed, my Bolt is a 56 235, 4 on the floor... like you my goal is to have a reliable daily driver.. I'm resurrecting, not restoring but I do want to keep the classic looks. I switched to an electronic ignition, added new wiper motor; windshield washer tank; radiator overflow tank; new wiring harness; turn signals (with flashing bulbs in the instrument panel); side mirrors; rear bumper; new (rebuilt) single carb; new door seals; I also completely redid the interior so I'd be driving in comfort. I have not done anything with the breaks and find them to be reliable. Steering dramatically improved after the new kingpins. Overall, I'm thrilled with how she rides and can clip along nicely at 50-55 on the highway. My next real wish is a radio... gets boring.
And oh yeah, I put in the all important cup holder for my coffee!
Good luck to you!! | | |
