5 members (1955 1 Series, TUTS 59, bluechev, Guitplayer, 1 invisible), 101 guests, and 1 robot.
Topics128,030
Posts1,055,418
Members48,422
#521254 03/26/2009 8:11 PM
Can someone tell me if panel/suburban runningboards are different than truck runningboards. '47-'54
I was placing an order with Classic Truck Parts today and they tell me that the truck boards wont work on the panel trucks.
Thanks Brent
OLTrucks
Unregistered
OLTrucks
Unregistered
Well dare I say they don’t know what they are talking about................................... No I better not Oooops already did. Did you ask them to check their master parts book?
Yes they are the same 1/2 pick-up, 1/2 panel , suburban All 47-55 1st and 1/2 ton canopy express.
Same goes for 1 ton pick-up, 1 ton panel and 1 ton canopy express also can share the same running boards.
Mike
#521303 03/26/2009 10:58 PM
Trucked Up,
You were told that the truck (pick-up body, we presume) running boards are different from panel body running boards - Mike is, of course, correct.
The only difference is that there would be two unnecessary holes when installed on the panel body - these holes were filled with rubber plugs at the factory (and, Jim Carter sells the plugs.).
Tim
Brent,
I would try Oklahoma City -http://www.mar-k.com/ They specialize in repo parts made in OK. Tell them it is for a truck.
Great products.
Don't forget the rubber that hides the gap between the boards and cab.
Sully
Sully
TCLederman and OLTrucks are right.
