2 members (BillyDon, Phak1),
102
Mod | | | Forums66 Topics128,272 Posts1,058,319 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#52138 11/10/2005 7:15 PM | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | I just spoke w/Mike Yoder @ Kansas Kustoms-Seems like a real nice guy. He splits stock cast iron manifolds into duals, keeping the intake fuel heater intact. My question is a follows:
In a '54 GMC with a chevy 235 (appx '55-'57) would I have better clearance running the second pipe behind or in front of the existing pipe? Mike can make the new manifolds either way. Also, would you guys run both pipes to the same side?, out the rear or beneath the running board?
Any input would be greatly appreciated. | | |
#52139 11/10/2005 8:02 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | My Fenton puts the front pipe in front and it works fine in my 53' 3100. I then ran it to a 3" collector pipe and then into a 2 in/2 out muffler. My choice was to run both out the rear with SS tips for that classic look. Only problem was choosing the right muffler for the sound I wanted but got it right on the third try. | | |
#52140 11/10/2005 9:09 PM | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | Moneypit, are you saying that your duals run together and then get split again?
Also, what was your evolution & final choice for the mufflers? | | |
#52141 11/15/2005 6:56 AM | Joined: Nov 2005 Posts: 146 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 146 | just make sure your pipes exit far enough back to not let fumes in the cab. doing as many exhaust systems as ive done, ive seen too many customers come to get pipes changed that were not put in a safe place,and were gasing the people out. and make sure the under side of the cab dosnt have a lot of holes in it. | | |
#52142 11/16/2005 3:30 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | If I had a Chevy engine in a GMC I don't believe I'd be shouting it to the world. | | |
