8 members (2-Ton, MNSmith, mick53, TUTS 59, Cletus1950, Peggy M, klhansen, EchoBravoSierra),
101
Mod | | | Forums66 Topics128,173 Posts1,057,041 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 38 Apprentice | | Apprentice Joined: Apr 2006 Posts: 38 | Does anybody know of any brake/clutch pedal assemblies (newer models) that will bolt into an 53 chevy truck cab? I want to mount a brake booster onto the fire wall eventually?
Any ideas?
Nick | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Booster under the floor with factory pedals would be (and is) my first choice for an AD truck.
Why do you want a booster in the engine compartement... That's where the engine goes right?
Grigg | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | I agree with Grigg - I'd prefer to keep the brake booster under the floor. But -if you are set on mounting the clutch/brake pedals as the swing design (instead of thru the floor) contact Master Power Brakes or Engineered Components Inc. (ECI). They have aftermarket pedal set ups. You will be using a hydraulic clutch with this set up. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I like a neat firewall. That said don't look at mine, it's much busier than I like. Putting a MC up there is just nasty.
~Jim
