| | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 29 | Can someone tell me if panel/suburban runningboards are different than truck runningboards. '47-'54
I was placing an order with Classic Truck Parts today and they tell me that the truck boards wont work on the panel trucks.
Thanks Brent
| | | | | | OLTrucks Unregistered | | OLTrucks Unregistered | Well dare I say they don’t know what they are talking about................................... No I better not Oooops already did. Did you ask them to check their master parts book?
Yes they are the same 1/2 pick-up, 1/2 panel , suburban All 47-55 1st and 1/2 ton canopy express.
Same goes for 1 ton pick-up, 1 ton panel and 1 ton canopy express also can share the same running boards. Mike | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Trucked Up, You were told that the truck (pick-up body, we presume) running boards are different from panel body running boards - Mike is, of course, correct. The only difference is that there would be two unnecessary holes when installed on the panel body - these holes were filled with rubber plugs at the factory (and, Jim Carter sells the plugs.). Tim | | | | | Joined: Feb 2009 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 95 | Brent, I would try Oklahoma City -http://www.mar-k.com/ They specialize in repo parts made in OK. Tell them it is for a truck. Great products.
Don't forget the rubber that hides the gap between the boards and cab.
Sully
Sully
| | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | TCLederman and OLTrucks are right. | | |
