1 members (Hotrod Lincoln), 130 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
TIP wink
here's an idea about making your own tail lamp using three of these LED strip items. you would have to make a base that fits securely inside the housing - vertically. the three could then be used for
http://cgi.ebay.com/LED-LIGHT-STRIP...332137286&_trksid=p4634.c0.m14.l1262
http://cgi.ebay.com/LED-LIGHT-STRIP...332142964&_trksid=p4634.c0.m14.l1262
stop eek
tail :mad:
blinker blush
OOpssss blush again
wire it w/ a 4 x22ga. wire [jacketed ]. they measure 1/2'' x 1.5'' and would fit inside the stock AD (or ???) housing.
the fourth being a common ground for all three LED's.
it could be similar to this
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=587685-R1-036-16A.jpg
I did a similar made turn signal set-up so the lens would fit into the roll of the bed using simple items available to most every one.
TIP::::: BLINKER SET-UP
i used two pieces of PVC or electrical 1''
a pair of 4 bulb LED's from a flaps store.
a hot glue gun
silicon
two wires soldered onto the LED socket and wired to the turn signal system
shrink tube
one clearance lamp lens , cut and shaped to fit the PVC
it looks like this when done..... dance
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=2A-1.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=587685-R1-018-7A.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=587685-R1-016-6A.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=587685-R1-014-5A.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=587685-R1-024-10A.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=587685-R1-020-8A.jpg
Jim & Caroline
Good idea. I've bought from this e-bay vendor before, you'll get good products and service from him. He also carries a 1" round LED circuit board (8 LED's) that work great as bed roll stop/turn lights.
I made my bed roll lights from pvc tube and some 2" round leds I got at the local truck stop..Cheap.
I made turn signal set-up so the lens would fit into the roll of the bed using simple items available to most every one. thumbs_up
i used two pieces of PVC or electrical 1'' dia. cut about 1.5'' long
a hot glue gun
silicon
shrink tube
one clearance lamp lens , lens is cut and shaped to fit the PVC 1'' dia
Jim & Caroline
C. T., Whats the difference in "stop" and "brake"? I understand using two strips together for turn and brake and one for tail, just like a dual filament bulb, but you seem to be suggesting 3 functions?
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
see above correction
gettin' ahead of myself blush
Jim & Caroline
