7 members (walterhvogel, Jman, Tom McGrath, UtahYork, Materman, Rich'sToys, Wally / Montana), 107 guests, and 3 robots.
Topics128,035
Posts1,055,557
#5203 07/16/2004 6:37 PM
What do you guys use for a lube when honing engine cylinders? I've used ATF and or motor oil mixed with kerosene with no problems.The local machinist says never to use very light stuff like solvents, the hone leaves folded over pieces of metal that play hell with the new rings.
#5204 07/16/2004 6:57 PM
Tony - Does this mean your reworking that 216?
Fred
52 3600
69 C-10
#5205 07/16/2004 6:58 PM
I've used castrol 30wt mixed with Marvel mystery oil in a squirt can. Use just enough to keep hone from chattering if using a spring hone. Then I wipe out with ATF and check the quality of the hone pattern.
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#5206 07/16/2004 7:47 PM
Fred, I'm thinking about the 216,sort of.I suspect the exhaust valve seat area is cracked,as cylinders 4 and 5 have very leaky exhaust valves.Visiting the machinist lately,he told me to always use genuine honing oil for a quality job.I always break the glaze with a 240 stone,then knock off the tops with a brief use of a 400 stone.
#5207 07/16/2004 8:09 PM
I buy Sunnen honing oil in 5-gallon lots for my valve grinder and rod hone, and swipe a little for cylinder honing. A good substitute is 30W motor oil and Varsol solvent (mineral spirits), in a 50/50 mix. HOT water, Tide, and lots of elbow grease with a scrub brush is the only way I know to get the residual grit out of the cylinders after honing. I once wore out a set of rings in 2500 miles, from a solvent cleanup after a honing job!
