3 members (Gdads51, latroca52, 1 invisible),
73
Mod | | | Forums66 Topics128,205 Posts1,057,425 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 136 | how do you put the welting on rear fenders? Rivit it on in place first? | | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | We recommend using contact cement. You have to cut the welt tail with pie shape cuts every couple inches in the areas that are curved. Install with the bead of the welt against the fender outer surface so that when the fender is installed the welt is snuggly pressed against the bed side. That way, it seals the opening and prevents mud and water from coming out through the gap between the bed side and fender. Be careful to prevent contact cement from getting on the outer exposed part fo the fender, as it may damage the paint. Masking tape will help here.
Mar-Ktech | | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | While we're on the subject what years was welt used?
tx
Keith | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | C.T., Nice pics an great tutorial...your welting looks very profesional! I will be takin my back fenders off soon to install the welting...couldnt get that part done in time to have the 52 ready for the prom last spring so I just glued on sections of gasket material as a paint buffer..till I can do the welting right. Tim | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Keith,
It looks like Lindsay is referring to a 1958 truck.
Rear fender welt was not used by the factory on pickups between 47-55 (Advance-Design series) but welt was used on panel-body rear fenders during those years.
Others will have to post about pre-'47 and post-'55-1st series trucks. Jim Carter's catalog states that rear fender welt on pickups was not used from the factory from 1934-1972.
It seems odd that the factory did not use rear fender welt.
Tim
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | I did this a few times and in addition to Jim's methods I found that if a small hole is made with a leather punch at the end of the slits maybe 1/8" behind the bead the welting became much more cooperative and it would overlap so you could see how wide to make the pie cuts and end up without gaps or overlaps.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Apr 2008 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 136 | I was planning on doing the rear fenders to protect the paint on the 58 Is this a good idea? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | On my '54 pickup (which also did not come with rear fender welting), I plan to use a strip of tar-paper or a thin rubber strip between fenders and bed-sides (with no bead).
| | | | | Joined: Oct 2006 Posts: 339 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 339 | I would have to challenge Jim Carters catalog, My 52 had fender welting on the rear fenders when I disassembled it for restoration, and I purchased the welting from The Truck Store in Nashville Ga...mar-Ktech and Curt B have given good advice on installing it...Bill B | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Tim, I'm in total agreament with ya. Never had any on the AD pickups from the factory, if ya had anything there then someone put it there at a later date when they had the rear fenders off. As a safety against paint chipping on a restoration I would also use a strip of ant-squeek (15# tar paper) in the joint. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | but welt was used on panel-body rear fenders during those years. Mine didn't have any welting on the rear fenders...Joe | | |
