6 members (MrSnerdly, 5 Window 9434, FAST55, WICruiser, TUTS 59, Hawkman), 56 guests, and 0 robots.
Topics128,043
Posts1,055,615
Hi - new guy here - I found an original '58 chevy. Almost completely untouched. Been parked in a heated garage for the past 15 years or so.
I have not yet made the purchase as I am waiting for the cash from the sale of my 70 el camino. Deposit made, waiting for his tax return.
Anyway - in investigating the 58 the owner was able to get the engine turning over & despite the terpintine in the gas tank it ran for a few seconds with starting fluid.
My question for the group is this - The rear main seal leaked like crazy even though it was not running but for a few seconds. Can the rear main seal be replaced with the engine in the truck?
The owner said I could do this by dropping the pan, removing the rear bearing cap & tapping the seal out.
What do you think? I've never done that before.
1958 Chevy Apache 3200
bone stock 235
53k miles
3 on the tree
3B Offline
Hy Midget Farmer, yes the seal can be replaced with the engine in the truck. The original seal was a rope type, there has also been a "rubber type seal" developed to replace the rope type seal, hope that helps.
3B #512576 03/03/2009 1:30 PM
I believe that the neoprene seal will work in a 58, if that is what you want to use. Man, don't let a pesky little seal stop you from buying a classic beauty!!
1951 1 Ton Completed
sounds like an awesome find......
please post pics when you take possesion of the truck.
leonard
1957 Chevy 3100 1/2-Ton
Photobucket pictures
On a side note, why is there turpentine in the fuel tank? Are you referring to old gasoline? At any rate all the old fuel should be removed from the tank and lines before starting. You risk valves seizing and punching holes in pistons otherwise.
Cletis #512684 03/03/2009 7:28 PM
Yes - very old gas. I plan to clean the tank, rebuild the carb and replace the seal before trying to start it.
I also need to rebuild the master cylinder - but should replace it with a modern double.
Does anyone know where I can find a new rubber main seal?
bone stock 235
53k miles
3 on the tree
This might help. This and a lot more good info can be found in the Tech tips link above.
Your first link didn't work. Like the second one though.
bone stock 235
53k miles
3 on the tree
Riding in the Passing Lane
Any parts store can supply the rubber type seal for that.
1972 Chevy c10 Cheyenne Super
bone stock 235
53k miles
3 on the tree
Hi Midget Farmer,Welcome and nice find.
Just a note....please refer to the image posting guide on the forum. It keeps 'the Mods' happy.
Jock thumbs_up
More pix on Flickr.
farmer, you got a solid truck man....looks good.
did the 58's come with a metal bed, no wood ?
leonard
Looks pretty snazzy. Good luck with it smile
The '58 did not come with a metal bed. That & the wheels were the only mods I could find.
bone stock 235
53k miles
3 on the tree
OOPS! link to the image - not the image itself. Sorry mods!
bone stock 235
53k miles
3 on the tree
V
V Offline
Still a great looking truck!
leonard
I bet you knew the answer to that. Coulda just said what you meant.
Just sayin...
Nice truck, midget...
If you purchase it, can you get me a "to go" order from the store it is parked in front of? Seafood gumbo and dirty rice will do.
Boy, do I miss that food up here in the NW.
The CPA, never under estimate the value;
especially when he's driving an old Chevy truck!
1947 Chevy 1/2-Ton Advance Design in the Gallery
1951 Chevrolet 3100
Truck is being delivered tomorrow afternoon! Cant wait to start playing around with it. I already have a list of things to do just to get it running.
Wish me luck!
bone stock 235
53k miles
3 on the tree
Former Workshop Owner
Very nice '58 thumbs_up thumbs_up thumbs_up
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
Still don't have it! Driving me crazy - the guy's trailer lost a bearing & now I'm waiting for him to rent a trailer. I could have gone to get it myself by now. I should think about doing that.
bone stock 235
53k miles
3 on the tree
Got the new truck home on Thursday night. I love it!
I've already started to tear it apart. Working on the rear main seal now - another post -
Here is what I need to get it running.
It has a new starter, coil & good battery.
Rear main leaks (original rope seal).
15 year old gas in the tank. I am glad though it was full. I'd rather clean out gunk gas than have the tank be rusty.
Need to blow some carb cleaner through the fuel lines & rebuild the carb. Previous owner (thanks Tony) gave the the rebuild kit.
Master cylinder needs new seals - again provided by PO with the sale.
Missing ignition switch. Funny thing - I was told it was hot wired somehow but didn't take too close of a look figuring a wire harness isn't that much anyway. Turns out to be a paper clip jumping two sides of the plug to light the coil. All I need is the switch & I'm good to go.
Of course you all know - once I get it running & on the road is when all the real work begins. It needs new corners - passenger door skin & lower quarter.
Drivers window is rusted in place (lucky it is up). I will power wash the belly & brush on POR 15 to stop any issues from the bottom up & then decide if I want to paint it or just hit it with a satin clear coat to protect the metal, but keep the "old" patina of the worn out paint. Of course these things will take place in later years than this one.
First things first - get out the old rope seal....
bone stock 235
53k miles
3 on the tree
