1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#519382 03/21/2009 10:08 AM
TPB
Offline
I can't figure it out and two mechanics are perplexed. The sending unit is fine. The gauge always reads full. then I brought it to a mechanic and now it reads alittle above empty.The needle moves only a little. help.
TPB #519505 03/21/2009 9:13 PM
Have you tested the sending untit?
Measure resistance while moving the sending unit.
Could there be a chaff in a wire touching metal?
41chevy!! #519537 03/22/2009 12:36 AM
Ex Hall Monitor
Ex Hall Monitor
The sending unit should show 30 ohms in the full position and 0 ohms in the empty position using a multimeter.
Tiny #523680 04/02/2009 2:45 AM
Sounds like you may have a hole in your float. I had the same thing going on. Pull it out and take it off the rod and inspect it. If may have a small crack usually where it snaps onto the rod. If it is bad go to the wrecking yard and get one out of a older Chevy truck with the tank in the cab. When you put it back on make sure the longer end faces forward so you don't have to do it twice. Good luck...
Steve in Idaho
