2 members (Bill Hanlon, 1 invisible),
62
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 65 | I can't figure it out and two mechanics are perplexed. The sending unit is fine. The gauge always reads full. then I brought it to a mechanic and now it reads alittle above empty.The needle moves only a little. help.
| | | | | Joined: Mar 2009 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 49 | Have you tested the sending untit? Measure resistance while moving the sending unit.
Could there be a chaff in a wire touching metal? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | The sending unit should show 30 ohms in the full position and 0 ohms in the empty position using a multimeter.
| | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | Sounds like you may have a hole in your float. I had the same thing going on. Pull it out and take it off the rod and inspect it. If may have a small crack usually where it snaps onto the rod. If it is bad go to the wrecking yard and get one out of a older Chevy truck with the tank in the cab. When you put it back on make sure the longer end faces forward so you don't have to do it twice. Good luck...
Steve in Idaho | | |
