1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 27 Apprentice | | Apprentice Joined: Feb 2008 Posts: 27 | Gentlemen:
Was attempting to replace the speedo needle. Upon trying to bend the tabs off of the needle the needle appeared to break lose showing about a 4-5mm of the shaft? Does this part press in, or is it one direct shaft all the way thru?
How do I fix? Am I in for new speedo? | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Did you hold the shaft with needle nose and rock it loose or just yank it off? Was there play(4-5mm) before you removed? The speedo is kinda touchy and hopefully can be fixed. My 4t6 was pressed on. This most likely didn't help. I'm sure someone else had a similar problem and will chime in. Some pics of my speedo repair here. Have fun and good luck Dan | | | | | Joined: Feb 2008 Posts: 27 Apprentice | | Apprentice Joined: Feb 2008 Posts: 27 | Thanks Dan!
I was trying to push the tangback with a screwdriver and in yanked, broke pulled out. Kinda looks broke! | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | | | |
