6 members (Samantha, dt235sd, homer52, chevyb, wilbur53, 32Fordpuchoptop), 122 guests, and 4 robots.
Topics128,088
Posts1,056,124
Members48,435
Apprentice
Apprentice
Gentlemen:
Was attempting to replace the speedo needle. Upon trying to bend the tabs off of the needle the needle appeared to break lose showing about a 4-5mm of the shaft? Does this part press in, or is it one direct shaft all the way thru?
How do I fix? Am I in for new speedo?
Did you hold the shaft with needle nose and rock it loose or just yank it off? Was there play(4-5mm) before you removed? The speedo is kinda touchy and hopefully can be fixed. My 4t6 was pressed on. This most likely didn't help. I'm sure someone else had a similar problem and will chime in. Some pics of my speedo repair here. Have fun and good luck
Dan
Apprentice
Apprentice
Thanks Dan!
I was trying to push the tangback with a screwdriver and in yanked, broke pulled out. Kinda looks broke!
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Moderated by  ndkid275, Phak1
